You can change the recalled copy settings before making copies.
Copy settings are counted as single recent copy settings until the following times: If they are not set as a single setting, the settings cannot be recalled with [Previous Settings].
When you press the control panel power switch
When you press
(Start)When you press
(Reset)When the Auto Reset mode activates
When Favorite Settings are recalled
You cannot recall the Merge Job Blocks mode with [Previous Settings].
The Standard mode cannot be recalled or stored.
Identical copy settings are stored only once in memory.
The cascade copy settings stored in [Previous Settings] are changed to the local copy settings when the machine or the cascade copy printer is restarted. If you want to recall [Previous Settings] and perform cascade copying, turn ON the main power of the printer → update the information for the cascade copy printer after the time set in [Startup Settings] has elapsed. (See "Cascade Copy Communication Timeout.")
Once stored, the last three copy jobs are kept in memory even if the main power is turned OFF.
