If you are copying onto the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray, Paper Deck Unit-B2: Load the side to copy on face down.
Other Settings
Example of Stapling Position
Corner: Top Right
Double: Right
![]() LTR
Corner: Top Right
Double: Top
![]() 11" x 17", LGL, LTRR
Corner: Top Right
![]() LTR
Corner: Top Right
Double: Right
Preprinted paper
Loading location: Paper drawer
Preprinted paper: Face up
Loading location: Multi-purpose tray
Preprinted paper: Face down
Loading location: Paper Deck Unit-B2
Original
Loading location: Platen glass
Original: Face down
Stapling setting
Corner: Top Right
Double: Right
Corner: Top Right
Double: Right
Corner: Top Right
Corner: Top Right
Double: Right
Loading location: Feeder
Original: Face up
Stapling setting
Corner: Top Right
Double: Right
Corner: Bottom Right
Double: Right
Corner: Top Right
Corner: Top Right
Double: Right
Auto Rotation Setting
Both ON and OFF available
Both ON and OFF available (ON when loaded vertically in the multi-purpose tray or vertically in a paper drawer)
Other Settings
Corner: Top Left
Double: Left
![]() LTR
Corner: Top Left
Double: Top
Corner: Top Left
![]() LTR
Corner: Top Left
Double: Left
Preprinted paper
Original
Original: Face down
Stapling setting
Corner: Top Left
Double: Left
Corner: Top Right
Double: Right
Corner: Top Left
Corner: Top Left
Double: Left
Original: Face up
Stapling setting
Corner: Top Left
Double: Left
Double: Right
Corner: Top Left
Corner: Top Left
Double: Left
Other Settings
Example Output
![]() LTR
![]() LTR, LTRR
Preprinted paper
Original
Original: Face down
Original: Face up
Function
Functions Unavailable for Combination
Preset Zoom
Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Set by Length*1, N on 1*2, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Print/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2
Zoom by Percentage
Preset Zoom*1, XY Independent*1, Auto XY Ratio*1, Set by Length*1, N on 1*2, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Print/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2
XY Independent
Preset Zoom*1, Zoom by Percentage*1, Auto XY Ratio*1, Set by Length*1, N on 1*2, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Print/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2
Auto XY Ratio
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Set by Length*1, Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Repeat Images
Set by Length
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, N on 1*2, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Print/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2
Fit to Page
Multi-Purpose Tray: Free Size, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark
Photo Printout
Printed Image*1, Text*1, Text/Photo*1
Printed Image
Photo Printout*1, Text*1, Text/Photo*1
Text
Photo Printout*1, Printed Image*1, Text/Photo*1
Text/Photo
Photo Printout*1, Printed Image*1, Text*1
Function
Auto XY Ratio, Automatic Paper Selection (Auto Orientation)*1, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, N on 1, Shift (By Position)*3, Shift (By Numeric Keys)*3, Front Cover, Insert Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals*3, Repeat Images
Auto XY Ratio, Automatic Paper Selection*1, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, N on 1, Shift (By Position)*3, Shift (By Numeric Keys)*3, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals*3, Repeat Images
Paper Drawer Auto Selection On/Off
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Transparency Cover Sheets
Multi-Purpose Tray
Auto XY Ratio, Fit to Page, Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Paper Drawer Auto Selection On/Off, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Saddle Fold, Scan Lock Information, Tracking Information, 1-Sided
2-Sided, 2-Sided 2-Sided, Book 2-Sided, Book 2 Pages, N on 1, Shift (By Position), Shift (By Numeric Keys), Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Superimpose Image, Repeat Images, Page Numbering, Copy Set Numbering, Print Date, Watermark, Store in Mail Box, Store in Mail Box: Copy upon Storing, Merge Job Blocks, Secure Watermark |
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Paper Drawer Auto Selection On/Off, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, 1-Sided
2-Sided, 2-Sided 2-Sided, Book 2-Sided, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Store in Mail Box, Store in Mail Box: Copy upon Storing |
Function
Collate
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Transparency Cover Sheets, Booklet*1, Booklet: Saddle Stitch*1, Booklet: Add Cover (Print/Leave Blank)*1, Booklet: Divided Booklet*1, Booklet: Creep Correction*1
Group
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Saddle Fold, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Copy Sample, Copy Set Numbering, Merge Job Blocks, Secure Watermark*4
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Saddle Fold, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Merge Job Blocks
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Copy Sample, Cascade Copy, Copy Set Numbering, Merge Job Blocks, Secure Watermark*4
Offset Collate
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Saddle Fold*1, Transparency Cover Sheets, Booklet*1, Booklet: Saddle Stitch*1, Booklet: Add Cover (Print/Leave Blank)*1, Booklet: Divided Booklet*1, Booklet: Creep Correction*1
Offset Group
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Saddle Fold, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Copy Sample, Copy Set Numbering, Merge Job Blocks, Secure Watermark*4
Staple
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Saddle Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction
Saddle Stitch
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple*1, Hole Punch, Saddle Fold, 2-Sided
1-Sided, Book 2-Sided, Book 2 Pages, N on 1, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Superimpose Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks |
Function
Hole Punch
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction
Saddle Fold
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, 2-Sided
Function
Interrupt
Cascade Copy
Reserved Copying
Cascade Copy
Multi-Purpose Tray: Free Size, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Secure Watermark
1-Sided
2-Sided |
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, 2-Sided
2-Sided*1, 2-Sided 1-Sided*1, Book 2-Sided*1, Book 2 Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction |
2-Sided
2-Sided |
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, 1-Sided
2-Sided*1, 2-Sided 1-Sided*1, Book 2-Sided*1, Book 2 Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Print & Check |
2-Sided
1-Sided |
Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, 1-Sided
2-Sided*1, 2-Sided 2-Sided*1, Book 2-Sided*1, Book 2 Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Print & Check |
Book
2-Sided |
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, 1-Sided
2-Sided*1, 2-Sided 2-Sided*1, 2-Sided 1-Sided*1, Book 2 Pages, N on 1, Erase Binding, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals, Repeat Images, Print & Check |
Book
2 Pages |
2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book 2-Sided, N on 1, Erase Binding, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals, Repeat Images, Print & Check |
N on 1
Preset Zoom*2, Zoom by Percentage*2, XY Independent*2, Set by Length*2, Fit to Page, Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Book
2-Sided, Book 2 Pages, Erase Original Frame, Erase Book Frame, Shift (By Position)*1, Shift (By Numeric Keys), Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals, Superimpose Image, Repeat Images, Mirror Image, Print & Check |
Fit to Page, N on 1, Erase Book Frame*1, Erase Binding*1, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark
Erase Book Frame
Fit to Page, N on 1, Erase Original Frame*1, Erase Binding*1, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark
Erase Binding
Fit to Page, Book
2-Sided, Book 2 Pages, Erase Original Frame*1, Erase Book Frame*1, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark |
Function
Gutter
Shift (By Position)
Automatic Paper Selection*5, Multi-Purpose Tray: Free Size, N on 1*1, Shift (By Numeric Keys)*1, Repeat Images, Mirror Image
Automatic Paper Selection*5, Multi-Purpose Tray: Free Size, N on 1, Shift (By Position)*1, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark
Front Cover
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Book
2-Sided, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Repeat Images, Mirror Image, Merge Job Blocks |
Insert Sheets
Automatic Paper Selection (Auto Orientation), Paper Drawer Auto Selection On/Off, Multi-Purpose Tray, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Saddle Fold, 1-Sided
2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book 2-Sided, Book 2 Pages, N on 1, Front Cover, Insert Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Superimpose Image, Repeat Images, Mirror Image, Print & Check, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks |
Function
Booklet
Preset Zoom*2, Zoom by Percentage*2, XY Independent*2, Set by Length*2, Fit to Page, Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Saddle Fold, Scan Lock Information, Tracking Information, 1-Sided
2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book 2-Sided, Book 2 Pages, N on 1*1, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift (By Numeric Keys), Front Cover, Insert Sheets, Transparency Cover Sheets, Different Size Originals, Cascade Copy, Superimpose Image, Repeat Images, Mirror Image, Print & Check, Print Date, Watermark, Merge Job Blocks, Secure Watermark |
Function
Copy Sample
Group, Rotate 90 Degrees: Group, Offset Group, Interrupt, Reserved Copying, Cascade Copy, Store in Mail Box
Automatic Paper Selection (Auto Orientation), Book
2-Sided, Book 2 Pages, N on 1, Shift (By Position), Shift (By Numeric Keys), Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images |
Cascade Copy
Multi-Purpose Tray: Free Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Interrupt, Reserved Copying, Saddle Fold, Scan Lock Information, Tracking Information, Shift (By Numeric Keys), Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Sample Copy, Mirror Image, Print & Check, Merge Job Blocks, Store in Mail Box, Store in Mail Box: Copy upon Storing, Secure Watermark
Sharpness
Scan Lock Information, Tracking Information, Secure Watermark
Superimpose Image
Multi-Purpose Tray: Free Size, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Scan Lock Information, Tracking Information, N on 1, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Print & Check, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box: Copy upon Storing, Secure Watermark
Nega/Posi
Scan Lock Information, Tracking Information, Merge Job Blocks, Secure Watermark
Repeat Images
Auto XY Ratio, Fit to Page, Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray: Free Size, Scan Lock Information, Tracking Information, Book
2-Sided, Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift (By Position), Shift (By Numeric Keys), Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals, Superimpose Image, Mirror Image, Print & Check, Merge Job Blocks, Secure Watermark |
Mirror Image
Fit to Page, Scan Lock Information, Tracking Information, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift (By Position), Shift (By Numeric Keys), Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Repeat Images, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box: Copy upon Storing, Secure Watermark
Function
Print & Check
2-Sided
2-Sided, 2-Sided 1-Sided, Book 2-Sided, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Superimpose Image, Repeat Images, Merge Job Blocks, Store in Mail Box |
Page Numbering
Fit to Page, Multi-Purpose Tray: Free Size, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Scan Lock Information, Tracking Information, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Transparency Cover Sheets, Superimpose Image, Mirror Image, Secure Watermark
Copy Set Numbering
Fit to Page, Multi-Purpose Tray: Free Size, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Scan Lock Information, Tracking Information, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Transparency Cover Sheets, Superimpose Image, Mirror Image, Secure Watermark
Print Date
Fit to Page, Multi-Purpose Tray: Free Size, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Scan Lock Information, Tracking Information, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Mirror Image, Secure Watermark
Watermark
Merge Job Blocks
Multi-Purpose Tray: Free Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Saddle Fold, Front Cover, Insert Sheets, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Print & Check
Store in Mail Box
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Sample Copy, Cascade Copy, Superimpose Image, Mirror Image, Print & Check
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Cascade Copy, Superimpose Image, Mirror Image
Secure Watermark
Multi-Purpose Tray: Free Size, Group*4, Rotate 90 Degrees: Group*4, Offset Group*4, Scan Lock Information, Tracking Information, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Print/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Cascade Copy, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark
