Clean the platen glass and the underside of the feeder before adjustment. (See "Originals Cannot Be Scanned Properly (Cleaning the Platen Glass).")
In order to use this function, the guide sheet is required. For more information, contact your local authorized Canon dealer.
Before adjustment, print the guide sheet (A3 or 11" x 17") under the following conditions. Accurate adjustment may not be possible if the guide sheet is not printed correctly.
Select the same size as the guide sheet.
Use paper with a weight of more than 200 g/m2.
Set the zoom ratio as 100%.
(Settings/Registration).
The larger the number of output test pages, the more accurate the adjustment is.
If specifying multiple output test pages, make sure that all of the test pages are scanned in the order they are output. If the order is changed or the scanning process is not performed successively, the adjustment may not be made correctly.
on the test page for the first scan operation with the mark on the guide sheet.
Open and close the feeder gently. Make sure that the guide sheet remains aligned when closing the feeder.
on the test page for the second scan operation with the mark on the guide sheet → press [Start Scanning].
on the test page for the third scan operation with the mark on the guide sheet →press [Start Scanning].
on the test page for the fourth scan operation with the mark on the guide sheet→press [Start Scanning].
