Adjusting the Total Amount of Toner
You can adjust the total amount of toner used for each paper type.
If you set this mode to [On], you can reduce the total amount of toner usage while retaining the CMYK values specified in Color Balance settings. As a result, you may prevent the quality of image from being affected adversely, and reduce the frequency of paper jams and paper feeding troubles.
This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Depending on the paper type, if the total amount of toner usage is reduced, density, color, and glossiness may change.
Press
(Settings/Registration).
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/ Edit].
4.
Press [Change] for <Toner Amount Reduct. Mode>.
5.
Select [On] → press [OK].
If you do not want to reduce the total amount of toner, select [Off].
6.
Press [OK].
