e-ManualTopSite mapHelp
Category Top
Overview of This Function
Registering Custom Paper Types
Changing the Name
Changing the Basis Weight
Changing the Size
Changing the Finishing Type
Changing the Type
Changing the Color
Setting the Second Side of Two-Sided Page
Adjusting the Creep (Displacement) Correction
Changing the Fiber Direction
Adjusting the Level of Curl Correction
Adjusting Fan Level for Paper Separation
Adjusting Paper Conveyance for 2-Sided Printing
Adjusting the Image Position
Correct Image Misalignment
Adjusting the Skew Correction Level of the Fed Paper
Correct Distortion (Parallelogram)
Correct Distortion (Trapezoid)
Adjusting the Zoom Ratio of the Image
Adjusting Left Edge Alignment of the Image
Adjusting Lead Edge Alignment of the Image
Automatically Correcting the Back Side Lead Edge Alignment of the Image
Adjusting Front/Back Side Edge Alignment of the Image by Scanning the Guide Sheet
Adjusting the Lead Edge/Tail End Margins
Adjusting the Total Amount of Toner
Adjusting the Secondary Transfer Voltage
Adjusting the Secondary Transfer Antistatic Bias
Adjusting the Image Clear Level of the ITB (Intermediate Transfer Belt)
Adjusting Secondary Transfer Belt Speed
Adjusting the Gloss and Fine Black
Adjusting the Saddle Stitch Position
Adjusting the Saddle Stitch Fold Placement
Adjusting the Saddle Fold Placement
Adjusting the Position of Punch Holes
Changing the Tail End White Patch Correction
Disabling Tail End Toner Correction
Adjusting the Primary Transfer Voltage
Adjusting Lead Edge Secondary Transfer Voltage
Deleting Custom Paper Types
Top » Paper Type Management » Adjusting the Lead Edge/Tail End Margins
0S9Y-05S
You can adjust the lead edge and tail end margins.
Depending on the paper type, if the lead edge and tail end margins are small, the paper is hard to be removed from the roller surface of the fixing unit. For that reason, the quality of the image may be adversely affected, output paper may be folded or bent at the corner, or the paper feeding troubles may occur.
In this case, you may improve the conditions by expanding the margin.
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/ Edit].
4.
Press [Change] for <Adjust Lead/Tail Margins>.
5.
Press [-] or [+] to adjust the lead edge and tail end margins → [OK].
You can also use the numeric keys to adjust margins.
If you want to expand the lead edge margin, adjust the setting value of <Lead Edge> toward [+] side.
If you want to expand the tail end margin, adjust the setting value of <Tail End> toward [+] side.
6.
Press [OK].
