: Paper that is registered from [Duplicate] or [Paper Database] with default settings.
: Paper that is registered from [Duplicate] or [Paper Database] with changed settings.|
[All]:
Displays all paper types.
[Standard Type]:
Displays only standard paper types.
[Custom Type]:
Displays only custom paper types.
You can edit only user-registered paper types.
You cannot change the detailed information or delete the paper type in the following cases:
When the paper type is being used for copy/print jobs
When the paper type is registered for the paper source (See "Registering the Paper Size and Type for a Paper Source.")
When the paper type is registered as the paper to adjust in [Register Paper to Adjust] in [Auto Adjust Gradation] (See "Automatic Gradation Adjustment.")
When the paper type is registered as the correction pattern in [Register Correction Pattern] in [Auto Correct Color Tone Settings] (See "Automatic Color Tone Correction.")
You can sort the paper type list by registration date (Reg'd (Asc.)/Reg'd (Desc.)), name (Name (Asc.)/Name (Desc.)), or basis weight (Weight (Asc.)/Weight (Desc.)) from the Sort List drop-down list.
