e-ManualTopSite mapHelp
Category Top
Overview of This Function
Registering Custom Paper Types
Changing the Name
Changing the Basis Weight
Changing the Size
Changing the Finishing Type
Changing the Type
Changing the Color
Setting the Second Side of Two-Sided Page
Adjusting the Creep (Displacement) Correction
Changing the Fiber Direction
Adjusting the Level of Curl Correction
Adjusting Fan Level for Paper Separation
Adjusting Paper Conveyance for 2-Sided Printing
Adjusting the Image Position
Correct Image Misalignment
Adjusting the Skew Correction Level of the Fed Paper
Correct Distortion (Parallelogram)
Correct Distortion (Trapezoid)
Adjusting the Zoom Ratio of the Image
Adjusting Left Edge Alignment of the Image
Adjusting Lead Edge Alignment of the Image
Automatically Correcting the Back Side Lead Edge Alignment of the Image
Adjusting Front/Back Side Edge Alignment of the Image by Scanning the Guide Sheet
Adjusting the Lead Edge/Tail End Margins
Adjusting the Total Amount of Toner
Adjusting the Secondary Transfer Voltage
Adjusting the Secondary Transfer Antistatic Bias
Adjusting the Image Clear Level of the ITB (Intermediate Transfer Belt)
Adjusting Secondary Transfer Belt Speed
Adjusting the Gloss and Fine Black
Adjusting the Saddle Stitch Position
Adjusting the Saddle Stitch Fold Placement
Adjusting the Saddle Fold Placement
Adjusting the Position of Punch Holes
Changing the Tail End White Patch Correction
Disabling Tail End Toner Correction
Adjusting the Primary Transfer Voltage
Adjusting Lead Edge Secondary Transfer Voltage
Deleting Custom Paper Types
Top » Paper Type Management » Adjusting Secondary Transfer Belt Speed
0S9Y-1LK
When the speed of the secondary transfer belt is not suitable, image problems such as roughness and vertical streaks may occur during double-sided printing on thin paper or printing on thick paper. In this case, adjust the secondary transfer belt speed.
This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Adjusting this function affects the zoom ratio setting (<Zoom (f)>). Always readjust the zoom ratio after adjusting this function. (See "Adjusting the Zoom Ratio of the Image.")
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/ Edit].
4.
Press [Change] for <Adj. Sec. Transfer Belt Speed>.
5.
Press [-] or [+] to adjust the secondary transfer belt speed → [OK].
You can also use the numeric keys.
If image problems occur on thin paper, press [+] to adjust.
If image problems occur on thick paper, press [+] or [-] to adjust. If the problem persists, adjust to the reverse side.
6.
Press [OK].
