This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
This adjustment for the fan level is not required since it is automatically adjusted by the main unit. However, the adjustment may prevent paper jam, multi-sheet feeding or corner fold.
The only adjustable setting for the POD Deck Lite-C1 is the side fan level.
[-5] to [-1]:
Select when high-density areas are not printed evenly, or when the amount of curl is at an unusually high level due to a lack of moisture, paper characteristics, and variable humid conditions.
[0]:
The default setting.
[1] to [5]:
Select when paper jams occur frequently, or when the temperature and humidity are high.
