e-ManualTopSite mapHelp
Category Top
Loading Paper
Loading Paper into a Paper Deck (Main Unit, POD Deck-D1 (Optional))
Adjusting a Paper Deck to Hold a Different Paper Size (Main Unit, POD Deck-D1 (Optional))
Loading Pre-Punched Paper
Loading Transparency/Clear/Translucent Film
Loading Tab Paper
Loading Paper into the POD Deck Lite-C1 (Optional)
Loading Paper into the LONG SHEET TRAY-A1 (Optional)
Loading Paper into the Document Insertion Unit-N1 (Optional)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Cartridge in the Stapler Unit (Finisher-AN1/Saddle Finisher-AN2)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Saddle Finisher-AN2)
Removing Staple Waste (Finisher-AN1/Saddle Finisher-AN2)
Removing Punch Waste (Puncher Unit-BS1/Puncher Unit-BT1)
Operating the Limited Functions Mode
Replacing Cleaning Web Unit
Replacing the Toner Cartridge
Replacing the Waste Toner Container
Routine Cleaning
Originals Cannot Be Scanned Properly (Cleaning the Platen Glass)
Originals Cannot Be Scanned Properly (Cleaning Method of the Original Scanning Area)
Scanned Originals Become Dirty (Manual Feeder Cleaning)
Scanned Originals Become Dirty (Automatic Feeder Cleaning)
Output Paper Becomes Dirty (Cleaning Inside of the Main Unit)
Output Paper Becomes Dirty (Wire Cleaning)
Output Paper Becomes Dirty (Roller Cleaning)
Streaks and Gloss Unevenness Appear on Output Paper (Refreshing the Fixing Roller)
Streaks and Gloss Unevenness Appear on Output Paper (Adjusting the Fixing Roller Auto Refresh Level)
Cleaning the Touch Panel Display
Consumables
Top » Maintenance » Routine Cleaning » Originals Cannot Be Scanned Properly (Cleaning the Platen Glass)
0S9Y-08U
If the platen glass or the underside of the feeder is dirty, the original may not be scanned clearly, or the size of the original may be detected incorrectly.
The location of the Duplex Color Image Reader Unit-K1 is indicated in the following illustration.
Clean the platen glass and the underside of the feeder by following the procedure below.
This procedure is necessary only if the Duplex Color Image Reader Unit-K1 is attached.
Clean the platen glass and the underside of the feeder with a cloth which is wrung after being dampened in water, and then wipe them clean with a soft, dry cloth.
1. Clean the platen glass.
2. Clean the underside of the feeder.
If stains will not come out, clean the platen glass and the underside of the feeder with a cloth which is wrung after being dampened in water with detergent, and then wipe them clean with a soft, dry cloth.
Use the glass cleaning cloth provided as a machine accessory of the Duplex Color Image Reader Unit-K1 when simple cleaning.
When glass cleaning cloth becomes dirty, wash and rinse, and then spread it out to dry.
