This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
This function is enabled only when [Correct Tail End Toner Application] in [Adjustment/Maintenance] is set to [On]. (See "Disabling Tail End Toner Correction.")
(Settings/Registration).|
[Correction Level]:
Press [-] to decrease the value if high density images on the tail end of the paper are faint, or press [+] to increase the value if white patches appear in halftone images on the tail end.
[Correction Amount]:
Depending on the paper type and paper curl, the size of the area on the tail end of the paper where white patches appear may differ. You can use this feature to adjust the starting position to correct the area.
If adjusting the value does not eliminate the white patches, you can try to decrease the Secondary Transfer Voltage. However, note that decreasing the Secondary Transfer Voltage may adversely affect the images. Make sure to check the output result while adjusting the Secondary Transfer Voltage.
