e-ManualTopSite mapHelp
Category Top
Overview of This Function
Registering Custom Paper Types
Changing the Name
Changing the Basis Weight
Changing the Size
Changing the Finishing Type
Changing the Type
Changing the Color
Setting the Second Side of Two-Sided Page
Adjusting the Creep (Displacement) Correction
Changing the Fiber Direction
Adjusting the Level of Curl Correction
Adjusting Fan Level for Paper Separation
Adjusting Paper Conveyance for 2-Sided Printing
Adjusting the Image Position
Correct Image Misalignment
Adjusting the Skew Correction Level of the Fed Paper
Correct Distortion (Parallelogram)
Correct Distortion (Trapezoid)
Adjusting the Zoom Ratio of the Image
Adjusting Left Edge Alignment of the Image
Adjusting Lead Edge Alignment of the Image
Automatically Correcting the Back Side Lead Edge Alignment of the Image
Adjusting Front/Back Side Edge Alignment of the Image by Scanning the Guide Sheet
Adjusting the Lead Edge/Tail End Margins
Adjusting the Total Amount of Toner
Adjusting the Secondary Transfer Voltage
Adjusting the Secondary Transfer Antistatic Bias
Adjusting the Image Clear Level of the ITB (Intermediate Transfer Belt)
Adjusting Secondary Transfer Belt Speed
Adjusting the Gloss and Fine Black
Adjusting the Saddle Stitch Position
Adjusting the Saddle Stitch Fold Placement
Adjusting the Saddle Fold Placement
Adjusting the Position of Punch Holes
Changing the Tail End White Patch Correction
Disabling Tail End Toner Correction
Adjusting the Primary Transfer Voltage
Adjusting Lead Edge Secondary Transfer Voltage
Deleting Custom Paper Types
Top » Paper Type Management » Changing the Finishing Type
0S9Y-051
You can change the finishing type of the custom paper type.
If you select a finishing type which is different from the actual surface texture of the paper, paper jams may occur, and the quality of the image may be adversely affected.
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/ Edit].
4.
Press [Change] for <Finish>.
5.
Select the finishing type → press [OK].
6.
Press [OK].
