Changing the Basis Weight
0S9Y-04Y
You can change the basis weight of the custom paper type.
If you enter a value which is different from the actual paper weight, paper jams may occur, and the quality of the image may be adversely affected.
Press
(Settings/Registration).
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/ Edit].
4.
Press [Change] for <Basis Weight>.
5.
Press [-] or [+] to set the paper weight → [OK].
6.
Press [OK].
