e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
The Touch Panel Display
Setting the Main Menu Screen
Shortcut to Settings/Registration
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Position and Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Entering the Department ID and PIN
Login Service
Placing Originals
Platen Glass
Feeder
Loading Paper into the Stack Bypass-B1
Loading Envelopes into the Stack Bypass-B1
Loading Paper with the Stack Bypass Alignment Tray-C1
Available Paper Stock
Inserting and Removing Memory Media
Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Delivery)
Installing System Options/MEAP Applications (Manual)
Displaying the Installation Log
Performing a Communication Test With the Delivery Server
Updating Firmware
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
Forwarding Conditions List
Registered LDAP Server List
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Loading Paper into the Stack Bypass-B1 » Loading Paper with the Stack Bypass Alignment Tray-C1
0L3X-01F
By using the Stack Bypass Alignment Tray-C1, you can reduce the amount of skew of paper (i.e. paper is transported diagonally) which is fed from the Stack Bypass-B1, and prevent the image misalignment.
To set the positions of the paper alignment guides, follow the procedure described below to stabilize the paper alignment guides.
The Stack Bypass Alignment Tray-C1 is an optional product.
Slightly widen the slide guides of the Stack Bypass-B1 to match the width of the loaded paper.
Loosen the fixing roulette screws.
Loosen the four fixing roulette screws at the front and the back.
Slightly widen the paper alignment guides to match the width of the loaded paper.
4.
Fan the paper several times, and then align the edges by pushing the protruding edges in with your fingers.
CAUTION
Take care not to cut your hands on the edges of the paper.
If the paper is curled, straighten out curled paper prior to use, as shown below.
Straighten out a stack of paper as shown in the illustration below.
Curled Paper
Straightened Paper
5.
Load the paper into the Stack Bypass Alignment Tray-C1.
Make sure that the height of the paper stack does not exceed the loading limit mark ().
Up to 100 sheets (17 lb bond (64 g/m2)) of paper can be loaded into the Stack Bypass Alignment Tray-C1.
6.
Adjust the sliding guides of the Stack Bypass-B1 to match the size of the paper.
7.
Adjust the paper alignment guides to match the size of the paper loaded in the Stack Bypass Alignment Tray-C1.
Leave no space between the stack of paper and the guides.
8.
Repeat steps 5 and 6 once or twice, and align the sliding guide of the Stack Bypass-B1 with the paper alignment guide to match the size of the paper.
To prevent the copied images from being slanted or misaligned, make sure that the edges of the stack of paper are neatly aligned in steps 5 and 6.
9.
Tighten the fixing roulette screws to stabilize the paper alignment guide.
Tighten the four fixing roulette screws at the front and the back.
For information on how to select the paper type and paper size, follow the procedure from step 4 in "Loading Paper into the Stack Bypass-B1."
