e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
The Touch Panel Display
Setting the Main Menu Screen
Shortcut to Settings/Registration
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Position and Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Entering the Department ID and PIN
Login Service
Placing Originals
Platen Glass
Feeder
Loading Paper into the Stack Bypass-B1
Loading Envelopes into the Stack Bypass-B1
Loading Paper with the Stack Bypass Alignment Tray-C1
Available Paper Stock
Inserting and Removing Memory Media
Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Delivery)
Installing System Options/MEAP Applications (Manual)
Displaying the Installation Log
Performing a Communication Test With the Delivery Server
Updating Firmware
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
Forwarding Conditions List
Registered LDAP Server List
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Tone Settings
Tone Settings
0L3X-01K
Pressing on the control panel enables you to set various tones to sound, according to the operations performed or status of the device.
You can set whether to sound the following audible tones. The tones below sound at the following times:
Entry Tone:
When pressing keys on the control panel, keys on the touch panel display, or keys on a USB keyboard.
When turning ON the main power of the machine if you set [Quick Startup Settings for Main Power] to 'On' in [Preferences] (Settings/Registration). (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
Invalid Entry Tone:
When you press an invalid key on the control panel or touch panel display, or when the maximum number of characters is exceeded.
Restock Supplies Tone:
When the toner cartridge needs to be replaced.
Energy Saver/Sleep Tone:
When the machine goes in the Energy Saver Mode/Sleep mode.
When turning OFF the main power of the machine if you set [Quick Startup Settings for Main Power] to 'On' in [Preferences] (Settings/Registration). (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
Error Tone:
When a malfunction occurs (e.g., paper jam or operational error).
Job Done Tone:
After a job completes.
Forgot Original Tone:
When placing originals in the feeder while an original remains on the platen glass, or vice versa.
Press on the control panel.
Specify each setting → press [OK].
