e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
The Touch Panel Display
Setting the Main Menu Screen
Shortcut to Settings/Registration
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Position and Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Entering the Department ID and PIN
Login Service
Placing Originals
Platen Glass
Feeder
Loading Paper into the Stack Bypass-B1
Loading Envelopes into the Stack Bypass-B1
Loading Paper with the Stack Bypass Alignment Tray-C1
Available Paper Stock
Inserting and Removing Memory Media
Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Delivery)
Installing System Options/MEAP Applications (Manual)
Displaying the Installation Log
Performing a Communication Test With the Delivery Server
Updating Firmware
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
Forwarding Conditions List
Registered LDAP Server List
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » The Touch Panel Display » Entering Characters Using a USB Keyboard
0L3X-015
If you connect a USB keyboard to the USB port of the machine, you can enter characters using that keyboard instead of entering characters from the touch panel display.
When the Keyboard screen is displayed on the touch panel display, characters entered from a USB keyboard are displayed on the touch panel display.
Even when a USB keyboard is connected, you can use the Keyboard screen on the touch panel display, and  -  (numeric keys) on the control panel. For information on entering characters from the touch panel display, see "Entering Characters from the Touch Panel Display."
Entering characters from a USB keyboard differs from entering characters from the touch panel display on the following points:
You can only enter ASCII characters from a USB keyboard. You can also use the spacebar and the arrow keys.
It is not necessary to change the entry mode drop-down list on the touch panel display to enter characters that are not displayed on the touch panel display from the USB keyboard.
When the entry mode drop-down list is displayed on the touch panel display, you cannot enter characters from a USB keyboard.
To enter uppercase characters, enter the characters while holding the Shift key on the USB keyboard. Even if you press [Shift] on the touch panel display, the characters entered from the USB keyboard will not become uppercase.
The Enter key of the USB keyboard is only used to enter line breaks. Even when using a USB keyboard, it is necessary to press [OK] on the touch panel display when you have finished entering characters.
Keys that are not displayed on the Keyboard screen of the touch panel display, such as Delete, End, Tab, Esc, and the numeric keys and function keys, cannot be used on a USB keyboard.
The sound mode when entering characters with a USB keyboard can be changed by setting the sound mode when entering characters on the Keyboard screen of the touch panel display. For information on setting the sound, see "Tone Settings."
Do not insert the connector of the USB keyboard into the USB port at an angle. If you insert it at an angle or insert a connector of a shape that does not meet the USB specifications, the USB port may be damaged.
Some USB keyboards may not operate correctly, as described above.
Use a commercially sold USB keyboard.
To use a USB keyboard, [Use MEAP Driver for USB Input Device] must be set to 'Off' in [USB Settings] in [Preferences] (Settings/Registration). (See "Using the MEAP Driver for USB Input Device Connections.")
A USB keyboard can be removed at any time.
