: Available -: Unavailable|
Paper Type
Paper Source
Paper Drawer
Stack Bypass-B1
POD Deck Lite-B1
Multi-drawer Paper Deck-B1
Document Insertion Unit-M1
Thin 2
(14 lb bond to 16 lb bond (52 g/m2 to 63 g/m2)) ![]() |
Thin 1
(17 lb bond to 20 lb bond (64 g/m2 to 79 g/m2)) ![]() |
Plain 1
(20 lb bond to 24 lb bond (80 g/m2 to 90 g/m2)) ![]() |
Plain 2
(25 lb bond to 28 lb bond (91 g/m2 to 105 g/m2)) ![]() |
Recycled 1
Recycled 2
Recycled 3
Color 1
Color 2
Heavy 1
(29 lb bond to 34 lb bond (106 g/m2 to 128 g/m2)) ![]() |
Heavy 2
(35 lb bond to 40 lb bond (129 g/m2 to 150 g/m2)) ![]() |
Heavy 3
(40 lb bond to 66 lb cover (151 g/m2 to 180 g/m2)) ![]() |
Heavy 4
(67 lb cover to 80 lb cover (181 g/m2 to 220 g/m2)) ![]() |
Heavy 5
(82 lb cover to 140 lb index (221 g/m2 to 256 g/m2)) ![]() |
Heavy 6
(140 lb index to 110 lb cover (257 g/m2 to 300 g/m2)) ![]() |
1-Sided Coated 1
1-Sided Coated 2
(34 lb bond to 40 lb bond (129 g/m2 to 150 g/m2)) ![]() |
1-Sided Coated 3
1-Sided Coated 4
1-Sided Coated 5
1-Sided Coated 6
2-Sided Coated 1
2-Sided Coated 2
2-Sided Coated 3
2-Sided Coated 4
2-Sided Coated 5
2-Sided Coated 6
Matte Coated 1
(71 lb text to 85 lb text (106 g/m2 to 128 g/m2)) ![]() |
Matte Coated 2
(85 lb text to 100 lb text (129 g/m2 to 150 g/m2)) ![]() |
Matte Coated 3
(56 lb cover to 67 lb cover (151 g/m2 to 180 g/m2)) ![]() |
Matte Coated 4
(67 lb cover to 81 lb cover (181 g/m2 to 220 g/m2)) ![]() |
Matte Coated 5
(81 lb cover to 94 lb cover (221 g/m2 to 256 g/m2)) ![]() |
Matte Coated 6
(94 lb cover to 110 lb cover (257 g/m2 to 300 g/m2)) ![]() |
Textured 1
Textured 2
(24 lb bond to 28 lb bond (91 g/m2 to 105 g/m2)) ![]() |
Textured 3
Textured 4
Textured 5
Textured 6
Textured 7
Textured 8
Vellum 1*1
Vellum 2*1
Vellum 3*1
Transparency*2
Clear Film
Pre-Punched 1
Pre-Punched 2
Tab 1
*3 |
Tab 2
*3 |
Labels
(56 lb cover to 66 lb cover (151 g/m2 to 180 g/m2)) ![]() |
Bond 1
Bond 2
Bond 3
Letterhead
Envelope
*4 |
*5 |
Paper Size
Width x Length
Paper Source
Paper Drawer
Stack Bypass-B1
POD Deck Lite-B1
13" x 19"
13" x 19"
12" x 18"
12" x 18"
12 5/8" x 17 11/16"
12 5/8" x 17 11/16"
11" x 17"
11" x 17"
LGL
8 1/2" x 14"
LTR
11" x 8 1/2"
LTRR
8 1/2" x 11"
STMTR
5 1/2" x 8 1/2"
EXEC
7 1/4" x 10 1/2"
Custom Size*1
4" x 5 7/8" to 13" x 19 1/4" (100 mm x 148 mm to 330.2 mm x 487.7 mm)
*2*5 |
*3 |
*4 |
Envelope
ISO-C5
6 3/8" x 9" (162 mm x 229 mm)
No. 10(COM10)
4 1/8" x 9 1/2" (104.7 mm x 241.3 mm)
Monarch
3 7/8" x 7 1/2" (98.4 mm x 190.5 mm)
DL
4 3/8" x 8 5/8" (110 mm x 220 mm)
Nagagata 3
4 3/4" x 9 1/4" (120 mm x 235 mm)
Yougatanaga 3
Kakugata 2
9 1/2" x 13 1/2" (240 mm x 332 mm)
Custom Size
6"x9", 9"x12", 10"x13"
*6 |
*6 |
*7 |
If you are using pre-printed paper, bordered paper, or color paper, and the printed image is misaligned vertically as seen from the paper feeding direction, set to 'Off' for <Auto Adjust Left/Right Edge Alignment> in [Paper Settings] in [Preferences] (Settings/Registration). (See "Changing the Auto Adjust Left/Right Edge Alignment.")
Use paper soon after it is unpacked as the moisture absorption condition of paper may affect the image quality and paper feeding. Wrap any remaining paper in its original package and store it on a flat surface.
For instructions on loading paper, see the following sections:
"Loading Paper into a Paper Drawer" for paper drawers
"Loading Paper into the Stack Bypass-B1" for the Stack Bypass-B1
"Loading Paper into the POD Deck Lite-B1 (Optional)" for the POD Deck Lite-B1
"Loading Paper into the Multi-drawer Paper Deck-B1 (Optional)" for the Multi-drawer Paper Deck-B1
"Loading Paper into the Document Insertion Unit-M1 (Optional)" for the Document Insertion Unit-M1
The Stack Bypass-B1, POD Deck Lite-B1, Multi-drawer Paper Deck-B1, and Document Insertion Unit-M1 are optional.
Chlorine-free paper can be used with this machine.
The printed envelopes may be creased depending on how envelope is pasted together or the position of the flap.
