Initialize All Data/Settings Report
The Initialize All Data/Settings Report is printed automatically after the data in the machine is initialized using the Initialize All Data/Settings mode. You cannot set not to print the report.
The items printed for the report and a description of each item are indicated below.
Prints the serial number of the imagePRESS machine you are using.
Prints the model name of the imagePRESS machine you are using.
Overwrite Method for Deletion Mode
The deleted contents and deletion mode are printed.
The Initialize All Data/Settings Report is printed in English only.
Although the job logs are deleted when the Initialize All Data/Setting mode is performed, the log which shows the Initialize All Data/Settings Report has been printed appears in [Job Log].
