e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
The Touch Panel Display
Setting the Main Menu Screen
Shortcut to Settings/Registration
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Position and Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Entering the Department ID and PIN
Login Service
Placing Originals
Platen Glass
Feeder
Loading Paper into the Stack Bypass-B1
Loading Envelopes into the Stack Bypass-B1
Loading Paper with the Stack Bypass Alignment Tray-C1
Available Paper Stock
Inserting and Removing Memory Media
Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Delivery)
Installing System Options/MEAP Applications (Manual)
Displaying the Installation Log
Performing a Communication Test With the Delivery Server
Updating Firmware
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
Forwarding Conditions List
Registered LDAP Server List
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Printing Reports » Store Log Report
Store Log Report
0L3X-02S
You can manually print the Store Log Report when required.
The items printed for the report and a description of each item are indicated below.
Stored At
Prints the date and time (in 24-hour notation) of when the storing of a file was completed. (An asterisk (*) indicates a job that has been printed on the Store Log Report before.)
Job No.
Prints the four digit number which is automatically assigned when a file is stored.
User
Prints the name of the user who stored the file.
Store to
The name and path for the store location of the file are printed.
If the ACCESS MANAGEMENT SYSTEM KIT is enabled when a logged in general user prints a Store Log Report, jobs performed by other users are printed with "***" in the Store to column. To see information in the Store to column, log in as an administrator.
Protocol
The type of store location (i.e. Memory Media) is printed.
The printed "Memory Media" means that a file is stored in a removable media such as USB memory from Scan and Store.
Result
Prints "OK" or "NG."
If a file storage operation is canceled, <STOP> is printed.
OK:
Storage was completed successfully.
NG:
Storage failed. The error code is also printed next to "NG."
If a field exceeds its display capacity, only those characters that fit in the display are printed.
Printing the Storage History
Press (Status Monitor/Cancel).
Press [Job] → [Job Log].
Press the drop-down list → select the desired setting → press [Print List].
4.
Press [Yes].
5.
Press [OK].
