e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
The Touch Panel Display
Setting the Main Menu Screen
Shortcut to Settings/Registration
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Position and Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Entering the Department ID and PIN
Login Service
Placing Originals
Platen Glass
Feeder
Loading Paper into the Stack Bypass-B1
Loading Envelopes into the Stack Bypass-B1
Loading Paper with the Stack Bypass Alignment Tray-C1
Available Paper Stock
Inserting and Removing Memory Media
Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Delivery)
Installing System Options/MEAP Applications (Manual)
Displaying the Installation Log
Performing a Communication Test With the Delivery Server
Updating Firmware
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
Forwarding Conditions List
Registered LDAP Server List
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » What This Machine Can Do
0L3X-00U
All the elements you will ever need in a color digital multitasking machine.
This machine incorporates a rich array of input and output features that can greatly enhance your efficiency. Equipped with features that meet the needs of document work, the machine represents the ultimate in color digital multitasking machines.
* Indicates functions, which require an optional product(s).
For information on the optional products required to use each function, see "Optional Products Required for Each Function."
Copying* (See "Copy.")
In addition to normal copying functions, convenient new functions, such as "Copy Sample" which helps to avoid copy errors, "Booklet" for making copies into booklets, and "Different Size Originals" for copying originals of different sizes together in one copy operation, are provided to increase your productivity.
Storing Scanned Data*/Printing Stored Data (See "Scan and Store" or "Access Stored Files.")
The Scan and Store function enables you to save document data that has been scanned from the scanner unit or created on a computer. The saved data can be printed at a specified time, or merged with separately saved data or data created on a computer for simultaneous processing.
You can set a file format (JPEG, TIFF, PDF, XPS, OOXML) for the scanned original, so that it can be accessed from your computer.
Sending Function* (See "Scan and Send.")
The Send function enables you to send scanned image or document data to file servers, or send it by e-mail or I-fax. A variety of file formats are supported (JPEG, TIFF, PDF, XPS, OOXML), which offer you greater flexibility in accommodating digital workplace environments.
If the Universal Send Advanced Feature Set is activated, you can add Office Open XML (pptx/docx) to the list of supported file formats.
Faxing* (See "Sending a Fax," or "Fax/I-Fax Inbox.")
By using the Remote Fax function, you can share the fax function with the remote fax server machine on the same network. Scanned documents, documents stored in the Mail Box/Memory RX Inbox, and data in the computer can be sent using the server machine by facsimile. You can also send documents to multiple addresses.
Printing (See "Printing from a Computer (Windows)" or "Printing from a Computer (Mac OS).")
You can use this machine as a high-speed network printer. Various outputs are also possible, such as 2-sided printing and page alignment.
If the imagePRESS Printer Kit is activated, or if the imagePRESS Server is attached, you can use this machine as the postscript printer with the Adobe PostScript3 software.
Using the Remote User Interface (See "Remote UI.")
You can control functions, such as confirming the status of the machine, job operations, and printing instructions for saved scanned data, all from your computer's Web browser.
Applying MEAP (See "MEAP.")
The MEAP (Multifunctional Embedded Application Platform) incorporated in the machine enables you to install applications to expand the functions of the machine.
Scanning Documents into Your Computer* (See "Scanner.")
The Network Scan function enables you to use this machine as a conventional scanner. You can scan a document using the machine, and read the data in an application you are using on your computer. You can scan images of up to 11" x 17" in size at a resolution of 600 x 600 dpi.
Applying Utilities (See "Software.")
You can specify various settings of the machine connected to a network when using utility software. You can specify initial settings, confirm the status of the machine, and manage documents.
