The machine can print a stamp (approximately 1/8" (3 mm) in diameter) on the front side of scanned and sent originals.
For information on the optional products required to use this function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Vertical Placement
* Position at which stamp is applied
Horizontal Placement
Place your originals in the feeder. The finished stamp is applied to the originals that are scanned from the feeder.
Press [Fax].
Specify the destination → press [Options] → [Finished Stamp].
Press [Close].
