Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Mac) » Importing an Address Book
08JK-11A
You can import an address book that has been saved as a file into the fax driver address book.
You can import the following file formats:
CSV (*.csv) files or extended LDIF format files (*.abk) exported from both Mac and Windows version fax drivers.
Extended LDIF format files (*.abk) exported from a supported device.
The fax driver for Mac supports only CSV format files that use commas as separators.
Select [Print] from the [File] menu of the application.
Select your fax → [General Settings] → click [Address Book].
Click [Import].
4.
Select the file you want to import → click [Open].
The data of the selected file is imported and displayed in the list under [Address Books].
The display may vary according to the operating system and system environment.
