Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Sending Fax Documents Manually
08JK-0WW
This mode enables you to manually send fax documents after checking that the destination is ready to receive fax transmissions.
For information on the optional products required to use this function, see "Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
If you have added additional lines, you can only use Line 1 (the standard line) for manual sending. Use Line 1 (the standard line).
To send documents consisting of two or more sheets, use the feeder.
If you cancel manual sending during sending, you can check the number of pages that were sent in the job log for [Send] on the Fax Activity Report or the Status Monitor/Cancel screen.
If you have set [Limit Functions] for [Department ID Management] in [Management Settings] (Settings/Registration) to 'Off' for any function, removing it from Department ID Management, you cannot perform manual sending. (See "Specifying Department ID Management.")
Place your originals.
Press [Fax] → [On-Hook].
Enter the recipient's fax number using  - (numeric keys),  and .
To use a one-touch button, press [One-Touch] → select the desired one-touch button.
If you know the one-touch button's three digit number, press  (One-touch Button Number) → enter the number for the desired one-touch button using  -  (numeric keys).
Make sure that you hear the dial tone before entering the fax number. If you enter the fax number before hearing the dial tone, the call may not be connected, or an incorrect number may be dialed.
You can specify the destination phone or fax number by selecting a one-touch button. For more information on one-touch buttons, see "Specifying Destinations Using One-Touch Buttons."
4.
Make sure that you hear the other party or carrier signal (a highpitched tone).
You can enter an extension number after dialing the fax number.
The level of the dial tone can be adjusted by pressing  or .
To cancel Manual Sending, press [End].
You can also set other functions before starting to send.
5.
Press (Start).
Scanning starts and the document is sent.
During the transmission, the destination's telephone number and page number are displayed in the message area.
