To configure the fax option settings, you must log on to your computer as a member of the Administrators group.
If you use this procedure in a shared printer environment, Canon Driver Information Assist Service must be installed on the print server. To install [Canon Driver Information Assist Service], select [Custom Installation] when installing the driver.
The display may differ according to the operating system and fax driver version.
] (Start) -> [Devices and Printers].
For Windows Vista, click [
] (Start) -> [Control Panel] -> [Printers].For Windows XP Professional/Server 2003, click [Start] -> [Printers and Faxes].
For Windows XP Home Edition, click [Start] -> [Control Panel] -> [Printers and Other Hardware] -> [Printers and Faxes].
For Windows Server 2008, on the [Start] menu, click [Control Panel] and then double-click [Printers].
If you want to share the fax, installing the Canon Driver Information Assist Service in the print server will enable you to use the [Get Device Status] function. To install [Canon Driver Information Assist Service], select [Custom Installation] when installing the driver.
If the fax and computer are connected via USB or a WSD (Web Services on Devices) port, the [Get Device Status] function is unavailable. You need to configure the settings manually.
