The machine allows you to receive faxes automatically or manually in several different ways.
See the following flowcharts to select the receive mode that you want to use.
The default setting is <Auto>.
You can set the incoming call ring time using "Incoming Ring."
*1
You can change the incoming call ring time using "Incoming Ring."
*2
To set a ring delay before the telephone starts ringing on an incoming call, go to the <Ring Start Time> option.
*3
To adjust the incoming call ring time, go to the <Incoming Ring Time> option.
*4
To specify how the machine behaves when you do not answer an incoming call, go to the <Action After Ring> option.
*1
Set the answer function to answer after a few rings.
*2
The message is recorded on the answer function (You are advised to add approximately 4 seconds of silence at the beginning of the message or set the maximum recording time to 20 seconds).
*1
When "Auto RX Switch" is set to <On> , the machine automatically starts receiving a fax after several rings.
*2
When "Remote RX" is set, you can dial the telephone to receive faxes remotely.
