Forwarding Received Faxes Stored in Memory to Other Destinations (Manual Forwarding)
When a fax is stored in memory, you can manually forward it to a specified destination.
Destinations that can be specified
You can specify the followings as destinations.
Fax
E-mail
File server
Group destination
1
Press [
] (Status Monitor/Cancel).
2
Select <RX Job> using [
] or [
] and press [OK].
3
Select <Job Status> using [
] or [
] and press [OK].
4
Select the job that you want to forward using [
] or [
] and press [OK].
You cannot forward received faxes when
the machine is in the middle of receiving another fax
the machine starts printing a job after it has received a fax
5
Select <Forward> using [
] or [
] and press [OK].
6
Specify the forwarding destination.
See the following sections to specify destinations.
