] (Menu) -> <System Settings> -> <Communication Management Settings> -> <Memory Lock Settings> (
If <Memory Lock PIN> is specified, use the numeric keys [
] to [ ] to enter those numbers, and then press [OK]. |
Off
Disable Memory Lock.
On
Memory Lock PIN:
Seven-digit number
Once the PIN is set, you are prompted to enter it every time you change or disable the Memory Lock mode settings.
Print Report:
Off, On
Specify whether to print the RX result report when receiving a fax.
Activate "Receive Results " to enable this setting.
Memory Lock Time :
Off, On
When <On> is set, received faxes are stored in memory only for a specified length of time.
Set <Memory Lock Start Time> and <Memory Lock End Time> respectively.
Memory Lock PIN
Press [OK] without entering any numbers when you do not want to set the PIN.
You cannot set a PIN consisting only of <0> (<0000000>).
When you set a PIN starting with <0>, the PIN is set in the following manner.
Example: When you enter <02> or <002>, the PIN is set as <0000002>. Memory Lock Settings operations
When memory lock settings are changed from <On> to <Off>, the documents saved in the memory up to then are combined and printed.
At <Memory Lock End Time>, you can combine and print received documents saved in the memory from the <Memory Lock Start Time> to the <Memory Lock End Time>.
