Configuring Send Settings
07K4-07E
This section describes how to configure the send settings.
See the following for more information.
The steps to take for configuring the send settings
Follow the steps in the procedure below to configure the send settings.
The procedure describes the steps to change the "ECM TX" setting.
1
Press [
] (Menu).
2
Select <Fax Settings> using [
] or [
] and press [OK].
3
Select <TX Function Settings> using [
] or [
] and press [OK].
4
Select <ECM TX> using [
] or [
] and press [OK].
5
Select <Off> or <On> using [
] or [
], and press [OK].
Select <Apply> when <Apply> appears on the screen after you have specified the setting and press [OK].
6
Press [
] (Menu) to close the menu screen.
The procedure is complete.
Configure the following options to send a fax.
Fax Settings
Basic Settings
