Configuring System Settings
This section describes how to configure the system settings.
See the following sections for more information.
The steps to take for configuring the system settings
Follow the steps in the procedure below to configure the system settings.
The procedure describes the steps to change the "RX Start Speed" setting.
1
Press [
] (Menu).
2
Select <System Settings> using [
] or [
] and press [OK].
3
Select <Communication Management Settings> using [
] or [
] and press [OK].
4
Select <Fax Settings> using [
] or [
] and press [OK].
5
Select <RX Start Speed> using [
] or [
] and press [OK].
6
Select the receive start speed using [
] or [
] and press [OK].
Select <Apply> when <Apply> appears on the screen after you have specified the setting and press [OK].
7
Press [
] (Menu) to close the menu screen.
The procedure is complete.
Configure the following options to receive a fax.
System Settings
Fax Settings
