See "Specifying the Default Fax Settings (PC Fax)" on how to display the [Edit Address Book] sheet.
You can register two fax numbers: a primary number and a secondary number.
You can register up to 3000 address entries for individual people.
To delete a registered item from the address book, select the item from the address book list and click [Delete].
If you specify two fax numbers for a single individual destination, two fax numbers with the same name will be displayed in the address book.
You cannot access or edit the address book if you do not have access permission to the destination folder of the address book. If this is the case, log on as user having access permission to the folder, or click [Specify a Folder] in the [Edit Address Book] sheet, and specify a folder, such as the [My Documents] folder, that you have write permission for as the destination folder of the address book.
You can also edit previously registered single person addresses. For more information, click [Help] in the bottom right-hand corner of the fax driver window to view the online help.
The display may differ according to the operating system and system environment.
