Category
Top » Fax » Using the Fax Functions » Changing Fax Settings (Settings that Can Be Specified Using the [Menu] Button) » Configuring Receiving Settings
Category Top
Preparing to Use the Fax Functions
Registering Destinations in the Address Book
Basic Sending Procedure
Basic Procedures for Sending Faxes
Specifying Destinations
Changing the Scan Settings (Fax)
Canceling Fax Jobs
Redialing (Manual Redialing)
Attention (Manual Redialing)
Useful Features
Notifying the Recipient of an Incoming Fax by Telephone (Manual Sending)
Attention (Manual Sending)
Push-button Telephone for Tone Dialing
Attention (Push-button Telephone for Tone Dialing)
Sending a Fax Abroad (Adding Pauses)
Sending to Multiple Destinations at a Time (Sequential Broadcast)
Attention (Sequential Broadcast)
Changing the Default Fax Settings
Configuring Send Settings
Register Unit Telephone Number
Select Line Type
Off-Hook Alarm
Change Defaults
Register Unit Name (Fax)
ECM TX
Pause Time
Auto Redial
Sender ID
Check Dial Tone Before Sending
Configuring System Settings
TX Start Speed
Address Book PIN
Restrict New Destinations
Allow Fax Driver TX
Restrict History TX
Fax No. Confirmation Re-Entry
Restrict Sequential Broadcast
Receiving Faxes
RX Mode
Changing the Receive Mode
Advanced Settings for the Fax/Tel Auto Switch Mode
Forwarding Fax Documents
Setting Document Transfer (Automatic Forwarding)
Configurating Operations for Transfer Errors
Re-forwarding/Printing/Deleting Documents in Which Transfer Is Failed
Forwarding Received Faxes Stored in Memory to Other Destinations (Manual Forwarding)
Managing Faxes Stored in Memory
Checking and Canceling Fax Jobs
Combining and Printing the Received Documents You Saved
Checking and Deleting Received Faxes
Checking the History of Received/Sent Faxes
ECM RX
Incoming Ring
Remote RX
Auto RX Switch
2-Sided Printing
Reduce RX Size
RX Page Footer
Continue Printing When Toner Is Low
RX Start Speed
Memory Lock Settings
Select Country/Region
Using PC Fax
Preparation to Use PC Faxing
System Requirements (PC Fax)
Where to Find Help (PC Fax)
Faxing Fundamentals (PC Fax)
Faxing (PC Fax)
Specifying the Default Fax Settings (PC Fax)
Setting Up the Fax Configuration (PC Fax)
Viewing the Online Help (PC Fax)
Useful Fax Functions (PC Fax)
Attaching a Cover Sheet (PC Fax)
Using the Address Book (PC Fax)
Selecting a Profile for Faxing
Registering a Person in an Address Book (PC Fax)
Registering a Group in an Address Book (PC Fax)
Importing Address Book Entries (PC Fax)
Exporting Address Book Entries (PC Fax)
Changing the Address Book Export Destination (PC Fax)
Collapse all|Expand all
07K4-08X
This section describes how to configure the receiving settings.
See the following for more information.
The steps to take for configuring the receiving settings
Follow the steps in the procedure below to configure the fax receiving settings.
The procedure describes the steps to change the "ECM RX" setting.
1
Press [] (Menu).
2
Select <Fax Settings> using [] or [] and press [OK].
3
Select <RX Function Settings> using [] or [] and press [OK].
4
Select <ECM RX> using [] or [] and press [OK].
5
Select <Off> or <On> using [] or [] and press [OK].
Select <Apply> when <Apply> appears on the screen after you have specified the setting and press [OK].
6
Press [] (Menu) to close the menu screen.
The procedure is complete.
Options
Configure the following options to receive a fax.
Fax Settings
RX Print Settings
