When You Use This Feature
Specify <Only When Error Occurs> to the <Store Images in Memory> of the <Store/Print When Fowarding>.
About re-forwarded job
The job which has been re-forwarded successfully is deleted.
] (Status Monitor/Cancel).
] or [
] and press [OK].
] or [
] and press [OK].
(1)
Select <Delete> or <Print> using [
] or [ ] and press [OK].![]()
(2)
Select <Yes> using [
] or [ ] and press [OK].![]() |
(1)
You can specify where to forward. You can specify only by the following approaches:
