Category Top
Overview of This Function
Flow of Copy Operations
Canceling a Copy Job
Reserved Copying
Changing Color Modes
Copy Sample
Confirming Prints during Copying
Recalling Previous Copy Jobs (Previous Settings)
Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Assigning Shortcuts
Changing and Canceling Copy Settings
Interrupt Mode
Changing Basic Copy Ratios
Zoom by Length
Setting the X and Y Axes Independently
Poster
Paper Selection
Book→2 Pages
Two-Sided Copying
Collating Copies
Booklet Mode
Perfect Binding
Job Build
N on 1
Add Cover
Inserting Sheets
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Inserting Sheets When Copying Onto Transparencies
Adjusting the Color
One Touch Color Mode
Page Numbering
Copy Set Numbering
Adjusting the Image Sharpness
Erase Frame
Watermark Printing
Date Printing
Shifting the Original Image
Gutter Mode
Print & Check
Inverting Images (Nega/Posi)
Repeat Images
Merge Job Blocks
Job Done Notice
Mirror Image
Area Designation
Print on Tab
Store in Mail Box
Superimpose Image
Various Features of the Express Copy Basic Features Screen
Operating the Express Copy Basic Features Screen
Setting Shortcuts on the Express Copy Basic Features Screen
Appendix|
If you scan different sized originals without setting the Different Size Originals mode or selecting a non-standard paper size as the paper size, the machine may not be able to detect whether your originals are color or black-and-white.
When the Auto (Color/B&W) mode is set, black-and-white copies are output at the same speed as color copies.
When the Auto (Color/B&W) mode is set and your originals contain color sections, the machine scans them in the Full Color mode. However, the machine may scan the color originals in the Black & White mode under the following conditions. To avoid this, set the color mode to 'Full Color'.
If the originals contain a few color sections.
If the color sections are located only in the areas of the originals, as indicated by the shaded portions of the illustrations below, when loading the originals in the feeder.
![]() If the color sections of the originals are close to black.
If the originals contain light color densities.
You can select Red, Green, Blue, Yellow, Magenta, or Cyan as the color in the Single Color mode and the Two Colors mode.
If [Use Auto (Color/Black & White)] in [Select Color Settings for Copy] is set to 'Off', [Auto (Color/B&W)] is not displayed. (See "Restricting Use of Auto-Color Select.")
If [Use Full Color] in [Select Color Settings for Copy] is set to 'Off', [Full Color] is not displayed. (See "Restricting the Use of Full Color.")
If a black-and-white document is copied in the Full Color mode, the Single Color mode, and the Two Colors mode, it is counted as a color copy.
(Main Menu) → [Copy].
If color printing is performed after black printing, a message may appear indicating the machine is preparing for color printing. Please wait for a moment until the message disappears. Color printing will start when the message disappears.
If you select [Sepia Tone] in the One Touch Color mode, the color mode is automatically set to 'Single Color'.
The default setting is 'Auto (Color/B&W)' for all the Copy functions.
If you want to use a desired color mode as the default setting, you can register the desired color mode in [Change Default Settings]. (See "Changing/Initializing the Default Settings for the Copy Function.")
If you set the Poster mode while the color mode is set to 'Auto (Color/B&W)', the color mode is automatically set to 'Full Color'.
