Poster
This mode enables you to enlarge an original to a size larger than 11" x 17" by copying parts of the original over several sheets of paper, and then pasting the sheets together.
You can specify the copy ratio for the Poster mode by percentage, or by setting the number of output pages that the original image should be copied over.
*1 Original
*2 Copy
*3 Copies Cut and Pasted Together
Determining the Copy Ratio and Number of Sheets Needed
If you create a poster by specifying the copy ratio, the number of output pages changes according to the size of the original, the copy ratio setting, and the size of the copy paper. Refer to the following table to determine the desired copy ratio.
Reproduction Ratio (%)
Paper Size
Total Sheets of Paper
Total Size
200
11" × 17"
9
22" × 34"
200
8 1/2" × 11" (LTR)
15
22" × 34"
200
8 1/2" × 11" (LTRR)
12
22" × 34"
300
11" × 17"
16
33" × 51"
300
8 1/2" × 11" (LTR)
28
33" × 51"
300
8 1/2" × 11" (LTRR)
25
33" × 51"
400
11" × 17"
25
44" × 68"
400
8 1/2" × 11" (LTR)
45
44" × 68"
400
8 1/2" × 11" (LTRR)
42
44" × 68"
The sizes indicated in the table serve only as a guideline. The actual copy ratio may be different from that indicated in the table.
After all the sheets have been pasted together, the final size of the actual copy will be slightly smaller than the size indicated in the table.
You can create a poster with copy ratios that are not listed in the table. However, the size of the original must not be larger than 11" x 17", and the copy ratio cannot exceed 400%.
Pasting the Sheets of the Divided Image Together
Example: Enlarging an 11" × 17" original by 282% to create an 22" × 34" vertical copy.
Size of Original:
11" × 17"
Orientation of Original:
Horizontal
Copy Size:
22" × 34"
Orientation of Copy:
Horizontal
Based on the above criteria, the table under "Determining the Copy Ratio and Number of Sheets Needed" indicates that when using 11" × 17" paper, 12 pages (4 × 3) are output.
The images on neighboring sheets created by the Poster mode overlap slightly. When pasting the sheets together, trim the overlapping portions, leaving an adequate amount of overlap to apply the glue.
The width of the overlapping portions differs, according to the copy ratio and paper size.
*Overlap
Place your original on the platen glass. The Poster mode cannot be used if the original is placed in the feeder.
If you set the Poster mode while the color mode is set to 'Auto (Color/B&W)', the color mode is automatically set to 'Full Color'.
The Poster mode cannot be used to make copies on custom size paper, transparency/clear/translucent film, and tab paper.
Copies of the original image made in the Poster mode overlap. Join neighboring sheets together by pasting over the overlapping areas.
You cannot make more than one copy of the original (over multiple sheets of paper) at one time using the Poster mode.
To cancel this setting, press [Copy Ratio] → [Poster] → [Cancel].
Specifying the Copy Ratio in Percentage
You can enlarge an original in the Poster mode by specifying the copy ratio in percentage. Any copy ratio from 100% to 400% can be set.
Press (Main Menu) → [Copy].
Press [Copy Ratio] → [Poster].
Press [Copy Ratio] → [Next].
4.
Use the numeric keys or press [-] or [+] on the touch panel display to enter a copy ratio → press [OK].
5.
Press (Start).
If you press (Stop) while copying is in progress to cancel the copy job and then press (Start) again, copying resumes from the first sheet of the divided image.
Selecting the Number of Output Pages
You can enlarge an original in the Poster mode by setting the number of output pages that the original image should be copied over.
Press [Number of Output Pages] → [Next].
4.
Press [Change].
If you are not changing the paper size, proceed to step 6.
5.
Select the desired paper size → press [OK].
6.
Select the number of output pages → press [OK].
You can select [4], [8], [9], or [16] for the number of pages.
Refer to the table under "Determining the Copy Ratio and Number of Sheets Needed" as a guideline for specifying the number of output pages.
The number of output pages that you have selected is used as a guideline. The actual number of output pages maybe less than what you have selected, depending on a combination of factors that determine the most appropriate number of pages. These factors include the size of the original, the selected paper size, and the enlargement ratio.
7.
Press (Start).
» Copy » Poster
0S9Y-0E3
