Print & Check
This enables you to confirm scanned images page by page when you scan originals in succession on the platen glass. This is useful to prevent miscopying resulting from misscanning.
Place your original on the platen glass. You cannot copy using [Print & Check] with the originals set in the feeder.
Press (Main Menu) → [Copy].
Press [Options] → [Print & Check] → [Close].
Press (Start).
Check the content of the output.
To copy the next original, place your original → press (Start)again.
To rescan an original immediately after scanning, reset the original → select [Re-Scan ] → press (Start).
If you want to change the scan settings, press [Change Settings]. If you want to change the settings, change them before pressing (Start).
Scan the originals until they are all scanned. Press [Start Copying] to start copying.
To cancel scanning, press [Cancel] or (Stop).
When [1-Sided2-Sided] is set, two-sided copying is not performed and the machine copies one original at a time.
» Copy » Print & Check
0S9Y-0F5
