For instructions on placing your originals, see "Placing Originals."
If [Auto Collate] is set to 'On', the Collate or Offset Collate mode is automatically set when you place your originals in the feeder. (See "Enabling Auto Collating.")
(Main Menu) → [Copy].
to display the desired mode.
(numeric keys) to enter the desired copy quantity (1 to 9,999).
(Clear)→ enter the correct value.|
You cannot change the copy quantity while the machine is copying.
The number of copies which can be set varies according to the copy modes you have set.
(Start).
(Start) to scan each original.
To cancel copying, press
(Stop). For information on canceling copying, see "Canceling a Copy Job."For information on interrupting a copy job to make priority copies, see "Interrupt Mode."
For information on starting to copy the next original while a previous original is printing, see "Reserved Copying."
We recommend you read the following topics before using the Copy function:
Main Power and Energy Saver key (See "Main Power and Energy Saver Key.")
Entering Characters from the Touch Panel Display (See "Entering Characters from the Touch Panel Display.")
Routine Maintenance (See "Routine Cleaning.")
If you are using Department ID Management, see "Entering the Department ID and PIN."
To cancel all settings and return the machine to the default mode, press
(Reset).For information on how to load paper, see the followings|
POD Deck Lite-C1: Loading Paper into the POD Deck Lite-C1 (Optional)
POD Deck-D1/Secondary POD Deck-D1: Loading Paper into a Paper Deck (Main Unit, POD Deck-D1 (Optional))
Document Insertion Unit-N1: Loading Paper into the Document Insertion Unit-N1 (Optional)
