Changing/Initializing the Default Settings for the Copy Function
0S9Y-147
You can change/initialize the default settings for [Copy].
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see
"Optional Products Required for Each Function."
Changing the Default Settings for the Copy Function
Press
(Settings/Registration).
Press [Function Settings] → [Copy] → [Change Default Settings].
Press [Register].
The current copy settings are set as the default settings.
4.
Press [Yes].
Press
Press [Initialize].
4.
Press [Yes].
