[Proof Print] appears while you are making multiple copies in the Collate, Offset, or Staple mode.
[Proof Print] can be used when the Finisher-AN1, the Saddle Finisher-AN2, or the High Capacity Stacker-H1 is attached.
[All Pages]:
Prints the entire print set.
[1 Page (Random)]:
Prints a page which follows by the currently printing page. One sheet of paper, which includes one page when performing 1-sided copying, and two pages when performing 2-sided copying, is output.
When proof printing is complete, the machine automatically resumes the job. If you need to adjust the settings, press [Cancel] or
(Stop) and then make a necessary adjustment. |
You cannot select [Proof Print] for the following jobs.
A job to which the Group or Offset Group mode is set
A job which is waiting to be copied or paused
A job which is currently interrupt copying
A job which is currently sample copying
A job which is currently proof printing
If the remaining copy is the last or nearly last, you cannot make proof print by selecting [All Pages].
If the pages in one copy are few, you may not be able to make proof print by selecting [1 Page (Random)].
It may take time to output even if you select [Proof Print].
