Text/Printed Image Mode
Text/Photo Printout Mode
Map Mode
Color Copy Original Mode
Printed Image Mode
Photo Printout Mode
Text Mode
(Main Menu) → [Copy].
[Text Priority]:
Priority is given to the faithful reproduction of text.
[Photo Priority]:
Priority is given to the faithful reproduction of photos, with as little moiré effect as possible.
If you make copies of an original containing halftones, such as a printed photo, the moiré effect (a shimmering, wavy pattern) may occur. If this happens, you can soften the effect by using [Sharpness]. (See "Adjusting the Image Sharpness.")
If the original is a transparency/clear/translucent film, select the original type → adjust the exposure to the most appropriate level for the original.
