Because only one copy is sent when using the fax driver, the [Copies] and [Collated] settings are ignored.
Depending on the application you are using, you cannot specify the output range in the upper part of the [Print] dialog box. If this is the case, specify the settings in the [Copies & Pages] preferences pane.
