Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Setting the Fax Send Time
06RH-0WW
You can store the data temporarily in the machine, and send the fax at a specified time.
Click [Sending Settings].
See "Faxing" or "Specifying the Default Fax Settings" on how to display the fax driver screen.
Specify the recipient name and fax number → click [Add to Destination List].
You can select the destination from the address book. For details about selecting a destination from the address book, see "Faxing."
If you have selected [Reenter Fax Number before adding Destination to [Destination List]] in the [Security Settings] dialog box of the [Special] tab, the [Confirm Destination] dialog box is displayed when you click [Add to Destination List]. For details, see the online help (see "Viewing the Online Help").
Select [Set the Time to Send] → specify the time to send the fax → click [OK].
The data is stored temporarily in the machine, and the fax is sent at the specified time.
The display may vary according to the operating system and system environment.
