06RH-0XK
Multiple pages of the original can be output on one sheet of paper by reducing the print size.
Select [Print] from the [File] menu of the application.
Select your fax → [Layout] → the number of pages you want to output onto one sheet of paper from [Pages per Sheet].
Select the page order from [Layout Direction].
4.
If you want to add a border to each page, select the line type from [Border].
5.
Click [Print].
The fax is sent with the specified layout.
If you select a cover sheet when sending, the layout is not applied to the cover sheet. The layout is only applied to the pages you are sending.
The display may vary according to the operating system and system environment.
