Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Using Subaddresses for Secure Transmission
06RH-0WU
You can send faxes using the subaddress function (a function that attaches a password and sends faxes to the destination's memory box).
If you enter a password with the subaddress when sending a fax, the document data is sent to a memory box in the destination's fax and stored. This function is convenient when sending confidential documents as faxes.
When using the subaddress function, the destination's fax must support subaddress communication.
Faxes can be sent using the subaddress function only when using a device that is provided with a fax board as standard.
For details about the options required for this function, see "Optional Products Required for Each Function."
Click [Sending Settings].
See "Faxing" or "Specifying the Default Fax Settings" on how to display the fax driver screen.
Specify the recipient name and fax number.
If the recipient is already registered in the address book, you can select the destination from the address book. For details about how to select an address from the address book, see "Faxing."
Click [Settings].
4.
Select [Use Subaddress] → enter a subaddress and password in [Subaddress] and [Password] → click [OK].
5.
Confirm the settings in [Advanced Function] → click [Add to Destination List].
If you have selected [Reenter Fax Number before adding Destination to [Destination List]] in the [Security Settings] dialog box of the [Special] tab, the [Confirm Password] dialog box is displayed when you click [Add to Destination List]. For details, see the online help (see "Viewing the Online Help").
6.
If you are sending to multiple destinations, repeat steps 2 to 5.
7.
Click [OK].
If you are using the subaddress function, the data is sent to and stored in a memory box in the destination device. The data can only be output if the correct password is entered.
The display may vary according to the operating system and system environment.
