Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Mac) » Faxing Fundamentals » Faxing
Faxing
06RH-0XH
The procedure for faxing a document created in an application is as follows.
Faxing methods may vary according to the application you are using. For details, see the instruction manuals provided with the application.
Select [Page Setup] from the [File] menu of the application.
Depending on the application you are using, the [Page Setup] dialog box may not be displayed. If this is the case, skip to step 4. You can specify [Paper Size] and [Orientation] in the [Print] dialog box.
Select [Page Attributes] from [Settings].
Select your fax from [Format for] → set [Paper Size], [Orientation], and [Scale] as necessary → click [OK].
4.
Select [Print] from the [File] menu.
5.
Select your fax from [Printer] → select [General Settings].
6.
Specify the fax destination.
When entering a new destination name and fax number:
When setting a destination from an address book:
Click [Add Recipient].
Enter the recipient name and fax number → click [OK].
To change a recipient name or fax number that has already been added, select the recipient from [Recipient List] and click [Edit Recipient].
Click [Address Book].
Select a recipient → click [] → [OK].
If you want to attach a cover sheet, configure the settings for the cover sheet in the [Cover Sheet] preferences pane.
For details about how to attach a cover sheet, see "Attaching a Cover Sheet."
8.
Click [Print].
Faxing begins.
Some printer models enable you to stop printing from a printer status confirmation/print cancelation display (see "Checking and Canceling Jobs from the Job Status Screen").
To stop sending data that is waiting to be output from Mac OS, click the printer icon in the Dock → click the name of the file you want to stop sending → click [Delete].
The display may vary according to the operating system and fax driver version you are using.
