Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Storing New Addresses » Storing Addresses Obtained via an LDAP Server
06RH-0SY
You can store an address obtained by searching the directory listings on the network using LDAP (Lightweight Directory Access Protocol) servers.
You may have to set up the LDAP servers beforehand, depending on the network environment. For more information on setting the LDAP servers, see "Registering an LDAP Server."
Press [Fax] → [Address Book].
Press [Register/Edit].
Press [Register New Dest.].
4.
Select [LDAP Server].
5.
Search for the desired destinations.
Perform the procedure in steps 4 to 9 of "Specifying Destinations Using the Address Book (LDAP Server)."
6.
Select the destination from the search results → press [Next].
You can select multiple destinations.
If you want to select the first 256 destinations, press [All (Max 256)].
To cancel a selected destination, select the destination again.
7.
Press [OK].
If you are managing Address Book access numbers, perform the procedure in step 9 of "Storing Fax Numbers."
The information that you can obtain via the LDAP server consists of only names and fax numbers.
If you want to select multiple destinations, select the destination Address List → press [OK]. If you set [Manage Address Book Access Numbers] to 'On', press [Access No.].
If you do not want to set an access number for the destination, press [OK] without entering any number.
8.
Press [Close] → [OK].
