Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Additional Lines
Additional Lines
06RH-0S7
Regarding G3 (Multi-line)
You can add two to four lines to the machine by installing the Super G3 2nd Line Fax Board, or Super G3 2nd Line Fax Board and Super G3 3rd/4th Line Fax Board. To add a line to the machine, it is necessary to register a separate telephone number for the additional line. (See "Setting the Line to Use When Sending.")
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Line 1 (the standard line)
Line 2 (the additional line): The Super G3 2nd Line Fax Board is installed.
Line 3 (the additional line): Super G3 2nd Line Fax Board and Super G3 3rd/4th Line Fax Board are installed.
Line 4 (the additional line): Super G3 2nd Line Fax Board and Super G3 3rd/4th Line Fax Board are installed.
