Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Specifying Copy Security Settings
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Required Condition
The Fax function is available for use.
The Send function is available for use.
Network settings are set.
You are logged in as the administrator.
Name
Enter a name for the destination.
Protocol
Select [Windows SMB].
Host Name
\\Computer name\PDF-Scan (Enter the computer name that you checked in step 1 in " Creating a Shared Folder (For Windows)", or step 2 in "Creating a Shared Folder (For Mac).")
Folder Path
If you want to create a folder named "Temporary" in the PDF-Scan folder, enter '\Temporary'. You can send without entering this field.
User Name
Enter the sender's user name (the name used to log in to the computer).
Password
Enter the password that corresponds with the user name.
(Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Forwarding Settings] → [Register].
(numeric keys) → press [OK].
The registered fax number for the sender may contain irregularities such as "dial zero", spaces, or the country code. Forwarding conditions may change depending on such irregularities. If you are unsure of the presence of irregularities, select [Contains] instead of [Equals].
For example, if you are unsure whether the sender's fax number is '03-3123-4567' or '003-3123-4567', select [Contains] and enter '03-3123-4567' for the fax number.
You can omit hyphens and spaces. In this case, enter '0331234567' for '03-3123-4567'.
Take note that if the forwarding condition is set to 'Off', faxes are output instead of automatically forwarding to a computer.
(Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Forwarding Settings] → [Forward w/o Conditions].
