Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Specifying Copy Security Settings
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)|
Required Condition
You are logged in as the administrator.
If you do not enter a PIN, you cannot display the Address Book from the Remote UI.
You can display or use the Address Book on the machine but cannot edit it.
(Settings/Registration) → [Set Destination] → [Address Book PIN].
(Settings/Registration) → [Function Settings] → [Send] → [Common Settings] → [Limit New Destination].
(Settings/Registration) → [Set Destination] → [Manage Address Book Access Numbers].
(Settings/Registration) → [Function Settings] → [Send] → [Fax Settings] → [Confirm Entered Fax Number].
(Start) is pressed.
(Settings/Registration) → [Function Settings] → [Send] → [Fax Settings] → [Allow Fax Driver TX].
(Settings/Registration) → [Preferences] → [Network] → [Firewall Settings] → [MAC Address Filter].
(Settings/Registration) → [Function Settings] → [Send] → [E-mail/I-Fax Settings] → [Restrict TX Destination Domain].
If the Main Menu screen is not displayed, press
(Main Menu). |
Encryption Level
Low (40-bit RC4)/Acrobat 3.0 or later
High (128-bit RC4)/Acrobat 5.0 or later
High (128-bit AES)/Acrobat 7.0 or later
Version for Viewing
Adobe Acrobat 3.0 or later
Adobe Acrobat 5.0 or later
Adobe Acrobat 7.0 or later
Allow Printing
Do Not Allow/Allow
Do Not Allow/Low Resolution Only/Allow
Allow Changes
Do Not Allow
Add Comments and Digital Signatures
Change but Add Comments/Extract Pages
Change but Extract Pages
Do Not Allow
Insert, Delete, or Rotate Pages
Add Digital Signatures
Enable Accessibility, Copy, and Extraction of Images/Text
If [Password Required to Change Permiss.] is set to 'On'.
Enable Copy and Extraction of Images/Text
SSL Encrypted Communication is a send/receive protocol that encrypts data on the Internet. This protocol is widely used to encrypt data on the Internet such as WWW and FTP, which enables confidential information including credit card numbers and trade secrets to be securely transmitted.
