Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Specifying Copy Security Settings
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)|
Required Condition
Network settings are set.
The printer driver is installed.
If you click [Get Device Status] on the [Device Settings] sheet, Mail Box names that were registered using the machine are reflected on the printer driver.
You can also set to print a document at the same time it is stored in the Mail Box.
If the Main Menu screen is not displayed, press
(Main Menu). |
(numeric keys) → press [Start Printing].
You can select multiple files stored in the Mail Box and send them at once.
You can enter a new destination on the Send Settings screen from the control panel of your imageRUNNER ADVANCE. When sending from the Remote UI, you can only select the destinations that are stored in the Address Book.
To send data stored in a Mail Box to a computer or other external device, an optional Send function must be available for use.
You cannot send CMYK data that was output and stored with a PS server or a compatible PS.
Type
Mail Box
Scan and Send
Documents Sent from a Computer
Print
(incl. Printing after merging) |
Yes
Yes
Yes
Change Print Settings
No. of print sets
Yes
Yes
Yes
Select Paper
Yes
Yes
Yes
2-Sided printing
Yes
Yes
Yes
Finishing
Yes
Yes
Yes
Staple
Yes
Yes
Yes
Saddle Stitch Booklet
Yes
Yes*1
Yes
Gutter
Yes
Yes
Yes
Cover/Job Separator
Yes
Yes
Yes
Page Numbering
Yes
Yes*1
Yes
Superimpose Image
Yes
Yes*1
Yes
Secure Watermark
Yes
Yes
Yes
Merge and Store
Yes
Yes*1
Yes
Move/Duplicate
(Moving to another Mail Box) |
Yes
Yes
Yes
Clear
Erase Document
Yes
Yes
Yes
Erase Page
Yes
Yes
Yes
Insert Document
Yes
Yes
Yes
Sending Documents*2
Yes
Yes
Yes*3
Backing Up Stored Data
Yes
Yes
Yes
Storage Capacity
Total
2,000 documents
Each Mail Box
2,000 documents
E-mail settings are set.
(1)
Press
(Settings/Registration) → [Function Settings] → [Store/Access Files] → [Mail Box Settings] → [Set/Register Mail Boxes]. |
(2)
Select the desired Mail Box.
(3)
Press [URL Send Settings] → select the destination (e-mail address/group) from the Address Book.
The machine is now set to automatically send an e-mail with a URL link to the location of the stored document.
If you scan documents from the Scan and Send screen, press [URL Send] on the screen for specifying the storage location.
(1)
Access the Remote UI → click [Access Received/Stored Files] → [Mail Box] → click the number of the Mail Box for which to set URL Send.
(2)
Click [Settings] → select [Set URL Send] → click [Address List] → select the destination.
