Category
Top » Practical Workflows » Internet Fax/Intranet Fax » Sending a Document via Internet Fax
Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Specifying Copy Security Settings
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Collapse all|Expand all
Internet Fax (I-fax) is a function that enables you to send and receive images via internet and not a telephone line.
Benefits from Using the I-Fax
Reduce transmission cost
G3 FAX transmission cost increases with transmission time and distance. If a line with fixed rate is installed, you can control the transmission cost because the cost of I-fax is fixed regardless of the transmission time and distance. It is recommended that you use this when sending and receiving documents with large number of pages.
High resolution transmission
You can send and receive at a resolution of up to 600 dpi. (for Full mode)
Confirm transmission
Confirmation result notice can be sent to the sender to check whether the document was sent to the recipient.
Required Condition
The Send function is available for use.
Network settings are set.
The recipient's machine can receive I-fax.
This section describes how to send I-fax via Full mode from the IPv4 environment.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below.
Preparations for Sending I-Fax
DNS settings
E-mail/I-fax settings
Send I-Fax Using the Touch Panel Display
You can operate this procedure using the touch panel display or the Remote UI.
Follow the procedures below to check whether the DNS server address settings are set.
Press (Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [DNS Settings] → [DNS Server Address Settings].
If it is not set, contact the System Manager and set the IP address for DNS primary server and DNS secondary server.
DNS server is a server that converts the computer's domain name into an IP address.
Check whether the host name and domain name are set in [DNS Host/Domain Name Settings] for <IPv4> on the DNS Settings screen.
If it is not set, contact the System Manager and set the host name and domain name. For the domain name, enter the domain name of the network to which the machine belongs to.
If dynamic DNS server is set, press [On] for <DNS Dynamic Update> in <DNS Dynamic Update Settings> on the DNS settings screen.
4.
Follow the procedures below to check whether the e-mail server is set.
Press (Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Communications Settings].
If it is not set, contact the System Manager and set each settings.
[SMTP Server]:
The IP address or host name of the e-mail server used to for transmission
[E-Mail Address]:
The e-mail address set on the machine
[POP Server]:
The IP address and host name of the e-mail server used to send and receive in "POP before SMTP" send authentication format
[POP Address]:
The log in name used to access the POP server
[POP Password]:
The password used to access the POP server
[POP Interval]:
The time interval in which the machine checks the e-mail on the e-mail server
It is recommend that you set [POP Interval] to an interval other than '0'.
5.
If the sending server requires authentication, check the authentication system by pressing [Authent./ Encryption].
[POP Authentication Before Send]:
If the provider is in the "POP before SMTP" send authentication system, set this setting to 'On'.
[SMTP Authentication (SMTP AUTH)]:
If the environment of the e-mail server requires SMTP authentication, set this setting to 'On' and enter the user name and password.
6.
Follow the procedures below to set the settings such as the maximum data size.
Press (Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Maximum Data Size for Sending].
The maximum data size for sending should not exceed the maximum data size for the e-mail server.
7.
Follow the procedures below to specify the TX timeout settings.
Press (Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Full Mode TX Timeout].
8.
If you want to print the TX report when the notice e-mail for TX report is sent, follow the procedures below to set [Print MDN/DSN upon Receipt] to 'On'.
Press (Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Print MDN/DSN upon Receipt].
9.
Follow the procedures below to set [Use Send Via Server] to 'On'.
Press (Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Use Send Via Server].
Using the Remote UI
You can specify the settings using the Remote UI.
Access the Remote UI → click [Settings/Registration].
If an error message is displayed and you cannot access the Remote UI, follow the procedures below.
Page Not Found:
(1)
Click [Tools] on the toolbar → [Internet Options] → select the [General] tab → click [Delete Files] in [Temporary Internet Files].
(2)
Select [Delete all offline content] on the Delete Files screen → click [OK] → restart the Web browser and access the Remote UI again.
HTTP 404 File Not Found:
Confirm that the IP address is correct.
Confirm the IP address setting range in "Network."
Updating DNS Automatically
(1)
Click [Preferences] → [Network] → [DNS Settings (IPv4)].
(2)
On the [DNS Settings (IPv4)] screen, check [Host Name] and [Domain Name].
(3)
If dynamic DNS server is set, select [DNS Dynamic Update Settings].
(4)
Click [OK].
Checking E-Mail Server Settings
(1)
Click [Function Settings] → [Send] → [Network Settings - E-Mail/I-Fax Settings].
(2)
If the sending server requires authentication, click [Authentication/Encryption Settings] → check the authentication system.
(3)
Click [OK].
Setting Maximum Data Size for Sending
(1)
Click [Function Settings] → [Send] → [Communications Settings - E-Mail/I-Fax Settings].
(2)
Click [E-Mail/I-Fax Common Settings] → enter the value in <Maximum Data Size for Sending>.
(3)
Click [OK].
Specifying TX Timeout Settings
(1)
(2)
Click [I-Fax Settings] → enter the value in <Full Mode TX Timeout>.
(3)
Click [OK].
Printing the TX Report when the Notification E-Mail Is Sent
(1)
(2)
Click [I-Fax Settings] → select <Print MDN/DSN upon Receipt>.
(3)
Click [OK].
Using Send via Server
(1)
(2)
Click [I-Fax Settings] → select <Use Send via Server>.
(3)
Click [OK].
Preparation for sending I-fax is completed.
Depending on the provider, port number 25 for send may be close to countermeasure junk mail. For more information, contact your provider.
Place your originals on the platen glass or in the feeder → press [Scan and Send] on the Main Menu screen.
If the Main Menu screen is not displayed, press (Main Menu).
Press [New Destination].
Press [I-Fax].
4.
Select [Full] from mode selection → select I-fax address → press recipient's condition. Enter the recipient's e-mail address as the I-fax address. Set [Send via Server] to 'On'.
5.
Specify recipient's condition → press [OK].
Specify the settings for paper size, compression method, and resolution according to the specification of the recipient's machine.
If the compression size is unknown, it is recommended that all of the compression methods (MH, MR, and MMR) are selected.
6.
Press (Start).
7.
Press (Status Monitor/Cancel) → [Send] → [Log] → check that the job was sent successfully.
If the result is <OK>, the job was sent successfully.
If the result is <NG>, the job was not sent because of an error.
One of the causes for failing to send is port number 25 for sending may be closed to countermeasure junk mail, depending on the provider. For information on changing the port of the machine, contact your local authorized Canon dealer.
Reference Information
Difference between Simple Mode and Full Mode
You cannot check whether the data was sent correctly to the recipient in the Simple mode. However, you can check whether the data was sent correctly to the recipient in the Full mode. Thus, it is recommended that the Full mode is set when you are sending a data.
Communication Activity Report
You can also confirm transmission by pressing (Settings/Registration) → [Function Settings] → [Send] → [Common Settings] → [TX Report].
Intranet Fax
By using the Intranet Fax that uses office LAN for TCP/IP protocol for IP transmission instead of e-mail server, you can reduce the transmission cost. (If the intranet fax is used, the address is <name in alphanumeric characters@IP address>.) Also, if the intranet fax is used, data is received when send transmission is completed.
As Intranet Fax can be used for transmitting data without using e-mail, the similar setting to e-mail is unnecessary. DNS and e-mail settings for the machine must be specified but the dummy values can be used.
Intranet Fax
I-Fax
Primary DNS Server
Enter a dummy (e.g. 123.123.123.1)
Required
Secondary DNS Server
Not Required
Required
Host Name
Enter a dummy (e.g. NiR)
Required
Domain Name
Enter a dummy (e.g. SMC Server)
Required
SMTP Receive
On
POP
On
SMTP Server
Required
E-Mail Address
Enter a dummy (e.g. 1F)
Required
POP Server
Required
POP Password
Required
POP Interval
Required
To use Intranet Fax, set [Use Send via Server] for each setting to 'Off'.
Function Settings (Settings/Registration) Screen
I-Fax Address Settings Screen
