Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Auto Adjust Gradation]
Paper Select, Start Printing key
No
No
[Correct Density]
Black Scan for Copy/Scan and Store (Mail Box), Black Scan for Send/Scan and Store (Other Than Mail Box), Color Scan for Send/Scan and Store: 9 levels each
5 levels
No
No
[Fine Adjust Zoom]
X: -1.0 % to +1.0 %, in 0.1 % increments
Y: -1.0 % to +1.0 %, in 0.1 % increments
X: 0 %
Y: 0 %
No
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Saddle Stitcher Staple Repositioning]*1
Start key
No
No
[Change Fold/Stitch Position]*1
-2.0 mm to +2.00 mm, in 0.25 mm increments
0.00 mm
No
No
[Adjust Fold Position]*1
-2.00 mm to +2.00 mm, in 0.25 mm increments
0.00 mm
No
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Clean Feeder]*1
Press Start
No
No
*1
If you are using the imageRUNNER ADVANCE 4035/4025, this item appears only when the appropriate optional product is available for use.
